400ex to 416 or 426
Old Jan 15, 2009 | 10:47 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Default 400ex to 416 or 426
<div class="FTQUOTE"><begin quote>Originally posted by: eprovenzano
If its top speed you want, adjust the gearing by adding a tooth on the front sproket, or dropping 1 - 2 in the rear. The 400 with its lugability, can handle a little higher gearing in the tight trails.
</end quote></div>
Well said. You have to watch adjusting the gearing. I had 22" rear tires which comes out about a tooth in front. I think it was a bit too much. I had problems stalling at times. Swapped out front to adjust and bam! Great clearance. Unstoppable on the trails!
Old Jan 15, 2009 | 10:54 AM
Koopa's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Koopa
</end quote></div>
Well said. You have to watch adjusting the gearing. It could probably handle adjusting the rear but, I had 22" rear tires which comes out about a tooth in front. I think it was a bit too much. I had problems stalling at times. Swapped out front to adjust and bam! Great clearance. Unstoppable on the trails!</end quote></div>
Old Jan 16, 2009 | 12:04 AM
thor440's Avatar
My 440 was sweet and comfy in the trails. I miss that tractor lugging power it had and would rather have it in many trail riding conditions cause the yfz wants to go. Although I loved my 440, and it lacked a good carb, it couldn't touch my yfz. I've seen ex motors that have been built by curtis sparks (super expensive) and other shops that can beat stock yfz's, but, spend a little on the yfz and bye bye!
Old Jan 22, 2009 | 12:15 PM
jac_23's Avatar
I have a 400 with full yosh exhaust and jetted,and on trails i keep right up to all the 450s, drag raced a stock 450r and was side by side till 5th gear he pulled away and also have heard of problems with the big bore kits so just my opinion
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
