Waterproofing Foreman
Old Feb 5, 2009 | 06:55 PM
12guns's Avatar
Default Waterproofing Foreman
I know about greasing the contacts, and raising the vent hoses, but how do I seal the pull starter assembly? Can I get by w/ covering the drain holes or does it need to come off??
Old Feb 5, 2009 | 08:50 PM
JeffinTD's Avatar
Highlifter is more of a deep water/mud oriented forum, and there are often discussions about that issue.
Some folks silicone the drain hole and the handle of the pull starter, but they also make a pull starter block off thing to replace the pull starter assembly.
The block off thing would probably be more reliably water tight, but using RVT or whatever on the handle and drain hole would still let you use the pull starter if you had to (and then reseal it).
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
Alex G.
Sep 19, 2015 06:34 PM
patrick.oc123
Sep 15, 2015 02:45 PM
