2007 Honda Rincon
Old Feb 7, 2009 | 03:59 PM
Cummins123's Avatar
Default 2007 Honda Rincon
Does any one have a diagram on how to remove the gas tank?
Old Feb 7, 2009 | 04:49 PM
JeffinTD's Avatar
In a nutshell, once you've got both tank side covers off, you've got some hoses and connectors to undo.
The fuel level sensor wire goes through a little holder, then to a connector. It needs disconnected.
On the rear part of the tank is a fuel vapor hose with a little spring clamp that needs undone.
Then there are 2 rubber straps up front, and 2 bolts on the sides.
The book says to tip the tank up and pull the fuel hose off the bottom. I find it easier to lift the rubber boot up on the subtank/pump, and unlatch that connector.
Sjrpp
May 2, 2023 03:59 PM
Nondem
Feb 22, 2020 12:20 PM
Sjrpp
Jun 2, 2019 07:25 AM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
ylomnstr
Sep 4, 2015 05:02 PM
