Blue Smoke
Old Feb 10, 2009 | 06:31 PM
T-Bone08's Avatar
Default Blue Smoke
Hi, I have a 2000 400ex with a 426 bore, cams, the whole nine yards. Its my buddys old racing bike. Well just recently I changed my fuel. I dont know if this would cause over heating and cause the blue smoke when I ONLY let off the gas. Instead of running about 104 I just have been using 100. What causes this?
Travis
Old Feb 12, 2009 | 11:32 AM
70judge920's Avatar
Default Blue Smoke
blue smoke on decelleration would indicate oil burning, make sure u do not have too much oil added,the 400ex is sensitve to overfilling. If that is not the problem it could be the valve seals,I had to replace mine,it is a comon proplem on the 400ex. I also have a 2000 ex with the 426 in. I had to replace and rehone the cyl because the machine shop didn't fit the piston right,I replaced with a namura piston and is right now no oil burning. I hope this helps.
Old Feb 12, 2009 | 12:02 PM
300exStroked's Avatar
Default Blue Smoke
Usually the rings or valve seals.. My buddies was doing it real bad.. i replaced the rings.. no more. Good luck.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
