help, my R won't start
Old Feb 11, 2001 | 08:40 AM
400exalltheway's Avatar
any other ideas?
Old Feb 11, 2001 | 11:54 AM
love250x's Avatar
My 250X won't start lots of the time, check the cdi box. Take the box out and spray some WD-40 in it then plug it back,that usually works for me. Good luck
Old Feb 11, 2001 | 12:51 PM
SuperFreak's Avatar
stock compresion should be 150 to 160 psi,have you checked your flywheel key?It may have slipped on the crank.
Old Feb 11, 2001 | 12:53 PM
my compression is 140. what do you mean slipped in the crank. do you me lose?
Old Feb 11, 2001 | 07:51 PM
  #15
SuperFreak's Avatar
Take the nut off the end of the crank at the flywheel and check out the key that keeps the the flywheel in time.It may have sheared,causing the flywheel to slip on the crank and be out of time.Do both of your top ends read 140 psi?If so you may have a bad gauge.Let us know what you find.
SuperFreak
Old Feb 11, 2001 | 08:02 PM
  #16
nope thats still good.still waiting for an answer if it could be the compression
Old Feb 11, 2001 | 08:15 PM
  #17
SuperFreak's Avatar
140 is low but I think it should at least crank on that much.Man I dont know!!!
SuperFreak
Old Feb 11, 2001 | 08:20 PM
  #18
yeah i'm at a lost too. someone from the 250r forum told me to check the poilet and main jet in case their cloged so i'm gonna try that. hope that works. shouldn't be clogged b/c of the fuel filter but i guess their always a chance.
Old Feb 11, 2001 | 08:27 PM
  #19
SuperFreak's Avatar
Take a coke bottle cap,fill it with gas and pour it down the the spark plug hole,put the plug back in and kick it,it should run for two or three seconds.if it does then you know its carburation.
SuperFreak
Old Feb 11, 2001 | 08:29 PM
  #20
should i put any oil in with that?
