Honda Problem!!!!!
Old May 26, 2009 | 03:37 PM
Chevyboiblues's Avatar
Cool
Again Thanx...I Have A 450r Now And Im Very Happy With It...Its a 06 With 13:1 piston,Hrc Cam,Power Bomb Header,Jetted Carb,Fmf Exhaust,
Old May 26, 2009 | 04:53 PM
Honda4LifeWes's Avatar
Hello, I don't know alot about four-wheelers like the rest of you but I know some of it. I had a question about my 03 Honda 400ex. I got in a little wreck the other day and for some reason the rear right back tire has been quite a bit wobbly. So I quickly checked it over, tightened the red thing inside of the tire and put the tire back on and made sure the nuts were on tight. It still wobbled of course and now I have no clue what to do??? Could it be the rim on the tire or something? Thank you!
Old May 26, 2009 | 05:37 PM
BEAVER.989's Avatar
You should have started your own thread, probably would get more response that way.
Anyhow, you likely bent a wheel, or worse yet, the axle. I'd get the wheels off the ground and give it a bit of gas in 1st gear. You should be able to easily see if it's the axle or not.
Old May 26, 2009 | 05:40 PM
I would have to agree..first thing..get it off the ground...and gas it a lil
Old May 26, 2009 | 08:23 PM
  #15
Thanks guys. I did what you said and the tire was spinning of course. Took the tire off and it looks like the red spindle holding the tire. Maybe the axle but the left one looks fine...? Can you replace the spindles?
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
