Honda 400 ex, white smoke coming from exhaust
Old May 22, 2009 | 12:43 AM
Williebee's Avatar
Default Honda 400ex white smoke
One other thing i've run across with these symtoms was exccessive carbon deopits in the combustion chamber causing the rings to stick and white smoke on take off , you could try adding some Sea Foam with your fuel it cleans the entire fuel system ; as well as cleaning exccessive carbon deposits in the combustion chamber i've seen it work on small engine's from as little as lawn and garden equiptment and as big as automobile engine's !
You can get it at all Auto Parts Stores and most Walmart super centers for around $7.00 plus tax , it works on both 2 and four stroke engines ; gasoline and deisel fuel this is the best fuel additive i've found and it's been on the market with a satifactory money back guarranty since 1942 !
Good luck with your 400ex , williebee......
Old May 22, 2009 | 12:50 AM
suzuki2009's Avatar
Default Sounds obvious...
Usually when your having white smoke it means you either have oil passing by the piston which means it needs bored out so you probably should pull of the top end and mic it all
MikeyBoyesq
Nov 27, 2020 02:44 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
Jake55
Jun 29, 2015 06:43 AM
joshuafromny
Jun 22, 2015 05:30 PM
lovinhonda
Jan 25, 2000 09:17 PM
