Does 2005 450r front shocks fit on 2002 400ex
I just recently put 2004 450r front shocks on my 05 400ex. they do fit however you need to knock the spot welded nut from the upper front shock mounts. then the 450r shock eyes hit on top because they are a little wider. you can custom cut the shock mount without weakening the integrity of the mount, or you could grind the shock eye which i wouldnt recommend. the first generation 400ex's and the 2nd generation 400ex's plastics are interchangable with slight modifcations, so the 450r shocks should fit. people might come on telling you that 450r shocks arent much better than stock 400ex shocks. i found that jumping the 400ex over small and medium jumps its much smoother. you do gain .2" of travel which isnt much.. however trail riding they feel about the same as stock boingers. you could spend a bunch of $$$$ and have the R shocks revalved and have triple rate springs put on. EBAY also has a triple rate spring kit for the R shocks. if you want the best bang for your buck buy some YFZ 450 shocks. they respond to adjustments much better than the R shocks and usually are cheaper. you will not be disappointed with the R shocks. dont change the rear 400ex shock with the R rear shock because it actually rides worse. i hope this helps
thanks for the help. cool that they will fit i just bought them on ebay but have not received them yet. my 400ex shocks are shot. Which i think the shocks helped ruin my bearing and the bushing in my steering shaft. which i also have on order. $$$$$$$$$$$
I would rather ask a new question anyways especially since this site is starting to look more like facebook. which i hate that website. i will get used to it. some things are better but i dont even know how to update my profile! the reason i would rather ask a new question is there might be and updated fix to your question
