2005 Honda Recon ES 1st gear indicator code/no start ?
2005 electric shift.
My nieces bike - did a spring tune-up on it today (airfilter,oil,New batt, exc) as a B-day present.
Turn the key on & the 1st gear indicator flashes at me 3 times then pauses, over & over.
Start button does nothing.... I`m assuming because the ECU says "no, your in gear"
Won`t downshift into N.
Jump starter solenoid and engine cranks, but won`t fire (with rear wheels off the ground) assuming again, ECU says "no spark for you - your in gear"
Dealer said "Angle Sensor is bad"
What is this (something that tells ecu where the shift drum is poitioned) ?
Where is this part & is it feasible that it is the problem ?
What are your thoughts ?
HELP ... is MUCH appreciated, as I have a little girl here giving me those "please fix it" puppydog eyes.
Thanks
Thanks
Jun 10, 2015 12:45 AM
