foreman 500 noise (help me please)
ok, rear yoke broke and bent the final shaft in rear. replaced everything and rear works fine. Now the front end makes a funny noise in the front diff. i took it apart and everything looked good. it makes a grinding noise, louder when around 5-7mph. when i turn the steering it stops. straight then starts again. when the yoke broke i was in 2wd. if any clues or suggestions please respond. thanks Hoy
splines look good. i took all that apart last night. the noise is the cam link inside the front diff. i took the guts out of the diff and turned it in my hands and it makes the same noise. it dosen't make noise until i install the front shafts into the diff. i'm going to get hot drain the diff fluid. then try lucas limited slip oil and see if it quits.
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
