cold start up
Old May 1, 2009 | 06:17 PM
gsjeepxr's Avatar
try a step up on the pilot. i went up 2 sizes and removed the choke and it starts perfectly all year long. just a suggestion.
Old May 1, 2009 | 09:10 PM
JeffinTD's Avatar
If you aren't planning mods, you could probably improve cold weather starting by bumping up idle mixture slightly, and maybe shim the needle up.
Also, if it is unusually cold blooded, disconnect the carb heater and take an ohm meter reading on the heater side (should be a handful of ohms), and check for voltage on the harness side when the key is on.
Actually, on that topic, when it is being cold blooded, are you waiting a few seconds between turning the ignition switch on and cranking? Are you using the primer ****?
Another thing that sometimes causes cold blooded/starting issues is not having the friction set high enough on the choke ****, so that it doesn't stay all the way out, or vibrates it's way in...
Old May 3, 2009 | 02:36 PM
chevy327's Avatar
thanks for the help..Yeah im having that problem with the choke not staying all the way out? They told me to bring it in a 50 hours for the valve adjustment..
Old May 3, 2009 | 08:10 PM
JeffinTD's Avatar
You turn the round housing for the choke **** to adjust friction.
Initial oil change and valve adjustment I believe is supposed to be at 20 hours, then every 100 hours after that.
Getting a factory service manual is something I always recommend for anyone who plans to keep a machine long term.
Old May 5, 2009 | 03:40 PM
  #15
chevy327's Avatar
ALright the book said 50 hours but im going to go ahead and take it in.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
86atc250r
Jul 28, 2000 02:40 AM
