2007 Rancher 420FE Reverse Problems
Old May 7, 2009 | 11:31 PM
Deadbleepingalien's Avatar
Default 2007 Rancher 420FE Reverse Problems
I have a 420 Rancher Electric Shift that is not shifting into reverse. It seems to do fine with the other gears but it won't go to R. When I am running through the gears, I can hear the shift motor working. When I engage the reverse control lever, (the little button deal attached to the left brake lever), the motor does not kick in.
I can shift it into reverse by using the manual shift tool but not when trying to use the electric switch. Sounds like the angle sensor is pretty problematic on these models. What does this control? Any ideas?
Old May 8, 2009 | 12:11 AM
I checked the code. I had 4 slow flashes and 2 fast ones.
Old May 8, 2009 | 05:26 AM
HondaMechanic's Avatar
Code #42 is the shift button up/down code ..
Old May 8, 2009 | 08:53 AM
So the problem is the shift selector button?
Sjrpp
May 2, 2023 03:59 PM
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
