40 pilote jet
Old May 24, 2009 | 06:59 PM
cdilbeck's Avatar
Default 40 pilote jet
Hello awhile back I asked you guys about my 400ex having a hard time starting and you guys said to change the pilote jet so i did that and it works great but now every once in a while it will want to die when i pull in the clutch do i need to adjust the carb now. Please let me know if you have any idieas for me. Thanks
Old May 24, 2009 | 08:08 PM
sprayedgt's Avatar
You shouldn't have to adjust the carb when changing a pilot jet. You could have let a little dirt in the carb after doing the jet change. Drain the bowl by taking off the 17mm bolt on the bottom of the carb, check and clean then reinstall and see if that helps.
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
