04 450 foreman electric proplem
Old Jun 6, 2009 | 11:06 AM
TraciK's Avatar
Default 04 450 foreman electric proplem
We recently bought a 04 foreman 450 and now everything is dead. Its not the battery because husband tried the battery in our new 4 wheeler and everything worked. Where to go from here? Any ideas what could be the proplem? Thanks so so much!
Old Jun 6, 2009 | 11:10 AM
TLC's Avatar
TLC
Check the fuses under the seat,may need replacing or cleaning,
Old Jun 6, 2009 | 03:54 PM
TraciK's Avatar
All the fuses are good
Old Jun 6, 2009 | 07:53 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Are you able to push start it????
Old Jun 7, 2009 | 08:49 AM
TraciK's Avatar
I don't think dh has tried that. I will ask him. Thanks
Old Jun 7, 2009 | 11:15 AM
TraciK's Avatar
Well, husband borrowed someone elses electric meter thing and it was the fuses. His meter is old, so he got to doubting the readings. There were 2 fuses blown. Yeah! That's fixed! Now to figure out why it is smoking so bad.
Old Jun 8, 2009 | 01:10 AM
07bloomfieldb's Avatar
The automotive fuses are easy to tell when blown because there is a gap, clearly visible. ( See below). The blue is good, the orangs is bad.
Attached Thumbnails 04 450 foreman electric proplem-wfc-fuse-blown.jpg   04 450 foreman electric proplem-fuse.jpg
Old Jun 8, 2009 | 11:31 AM
action450s's Avatar
There's also a main battery fuse, looks like a thin strip of tin.
You should find the reason that caused the fuses to blow, if everything is OK the fuse will never blow. If theres a wire damaged your going to have the same problem and probably burn something up in the process.
Old Jun 8, 2009 | 03:32 PM
TraciK's Avatar
I will tell husband about that main fuse. Thanks
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
