Run a winch without a battery?
Old Jun 9, 2009 | 10:48 AM
budedm's Avatar
Default Run a winch without a battery?
My 250X is a kick start and has no battery. Is it possible to hook up a winch to run off the voltage regualtor or something? Of course I know the bike will need to be running.
Old Jun 9, 2009 | 10:53 AM
upnort's Avatar
I doubt highly your machine could put out enough for a winch. A winch can draw a hundred amps, even a 1500#.
Old Jun 9, 2009 | 11:50 AM
budedm's Avatar
Ok, thanks.
Old Jun 9, 2009 | 12:07 PM
itch's Avatar
winch amps example on 4000 lb atv winch
Old Jun 9, 2009 | 04:48 PM
action450s's Avatar
You will definantly need a battery. The bike will not put out enough amps to keep the winch working. You will definantly blow the fuse, if you bypass the fuse you will burn something up guranteed.
Old Jun 11, 2009 | 03:46 AM
chuck_raduenz's Avatar
not a good idea. my wheeler has enough work trying to keep up with all the ele stuff on it. and thats with a battery. keep in mind the wires comeing from the stator coil arent that big, plus the stator is only gona put out so much power. and over powing it will either start to over heat wires, and other things.
toonces
Oct 19, 2015 02:21 AM
Karas3434
Aug 3, 2015 09:17 AM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
