250X goes through sparkplugs fast
Old Feb 17, 2001 | 04:46 PM
Need4Speed's Avatar
I've got an '87 250X and this thing goes through on average 1 plug ever 2 tanks of gas. The engine is stock the jetting is right and i've tried gapping it everywhere to see if that'd help and it didn't. Is this just something common that I'm going to have to live with?
Old Feb 17, 2001 | 08:56 PM
puddding's Avatar
oil?..;...compression rings.........may be time for em......makes a good excuse to do some mods while the lid is ofF!....
Old Feb 17, 2001 | 11:03 PM
Need4Speed's Avatar
I just had the top end off it to replace the cam bearing cover, it's not burning any oil or smoking at all and it has compression.
Old Feb 17, 2001 | 11:06 PM
rider820's Avatar
you sure the jetting is set right?
Old Feb 18, 2001 | 12:27 AM
luckywilson's Avatar
Try the float needle and needle seat. Replace them.When they go bad they let the gas go in the carb to fast and that forces the gas up the pilot jet and makes it run rich.
Old Feb 18, 2001 | 09:50 AM
Crawdad's Avatar
You have something out of whack somewhere. Our '87 250x can run all summer on the same plug.
Maybe your valves are out of adjustment. Also our decompression cable broke once and we started fouling plugs before we knew it had snapped. Make sure it is adjusted properly.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
