new tires help!
Old Jul 16, 2009 | 12:13 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
For the record, remember there is no "chain thing" on a shaft drive 250EX!
Clearance from the frame will not be a problem of any kind! Being radial, the SR's should give a nice ride! I have the ITP TrakStar radial on our 250's right now, and i bet they probably use the same casing. You will lose a little ground clearance and top speed, because they are shorter than the stock (22" front/22" rear) tires, but you will gain some low end power.
http://www.itptires.com/sportatv/holeshotsr.html
If I were doing the rear with a radial, I would probably also want a radial on the front. Note that the Baja rims are wider than stock and have a greater offset. This makes the quad several inches wider, for a nice increase in stability...but again I would not do the rear without also doing the front!
If you don't have money for the fronts as well, if it were me I would stick with the stock rims and just get new SR's all the way around.
Alex G.
Sep 11, 2017 11:38 PM
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
