Honda Recon 250 Wheels/Tires
I wouldn't put bigger tires or different wheels on it. It doesn't have enough power to turn bigger tires or heavier wheels. Just put some more aggressive tires on the back. I'd suggest putting stock size Mud Lite AT's on it. They weigh only slightly more than the stock tires but give you a lot more traction. Don't seem to affect performance at all. Though now I realize this was from 6 years ago so most likely he doesn't even own it anymore. It is a Honda though so I'm sure its still running whoever has it now.
Big difference between (AT) and (XL) The "AT" have 5/8th" lugs the XL are aggressive 1-1/8th" lugs.
I call (ATs) XL that come half worn out. I tell people to buy XL before ATs because they will turn into ATs after 1500 miles anyways.
The good thing about 2wd is you don't care if the front ties are almost bald.
#18
I think standard rims are 9" on Recons. We fit chevron tyres made for the 200 ATC. These fit the rims and are about as big as the arches will take, in fact if you blow them up too hard, they touch. Can't remember the size off hand.
