Help with 2002 rancher
Old Aug 28, 2009 | 08:48 AM
BRUCEW's Avatar
Default Help with 2002 rancher
Unit has k/n air filter the only mod.Had a problem with gas leaking from overflow tube on carb. Found that I had trash in carb cleaned the carb and installed in line fuel filter. Now I have trouble with starting. Although once unit starts it runs well.Except for wanting to crawl a little in gear.Any help would be greatly appreciated.
Old Aug 28, 2009 | 12:49 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I bet you don't have an owner's manual....huh????
As for crawling in gear, you may just need to turn the idle down a little. Black **** on side of carb. See owner's manual if you have one.
From another post....the clutch adjuster is a screw on the front of the engine. Again, see owner's manual! We have posted the procedure in here a hundred times, so I will try to find a link.
Flows gas out of the carb overflow.....you probaby have a bit of grit under the float needle. Mine had done this a couple times over the last 10 years that I have had it, and I just go out and land a few big jumps and that jars the float and the grit dislodges.
Old Aug 31, 2009 | 09:54 AM
BRUCEW's Avatar
Not yet have one ordered. Just purchased the atv . I have it fixed now thanks for the help.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
byronman
Sep 6, 2015 06:34 PM
