2003 rincon is stalling out why??
Old Sep 11, 2009 | 10:16 PM
jts_1979's Avatar
Default 2003 rincon is stalling out why??
My 03 rincon is stalling out while driving. I cleaned and rebuilt carb and the plug is clean can anyone help? it stalls out at higher speed like it wants to backfire but sosent.
Old Sep 12, 2009 | 05:53 AM
JeffinTD's Avatar
Welcome to the forum.
What exactly is it doing? Does it just not reach normal speed, or does power drop in and out like it's running out of fuel?
If it is the latter, I'd check that the fuel tank vent (cap and hose) is letting air in the tank to replace the volume of fuel as it is consumed. Easiest way to check would be to crack open the fuel cap when it is acting up (on a smooth surface so you don't splash yourself).
If it isn't that, then I'd guess the fuel screen hasn't been cleaned. Remove the tank, preferably when it isn't full, and there are two bolts on either side of the petcock. When you pull the petcock out, you will see a fine screen that you can spray clean with a can of carb cleaner and compressed air.
On the other hand, if it is reving high and acting like the rev limiter is hitting, then I'd suspect you may actually have a transmission issue. The Rincon is known for bulletproof reliability, but in the first year they could blow a large O ring seal inside. The result would be insufficient pressure to operate the transmission and they would exibit slipping, which usually shows up first in the high gear at high throttle.
From what you describe, though, I'd bet at high speed/high load the engine is pulling fuel out of the float bowl faster than it is running in- which leads me to the bad vent or clogged screen...
Good luck, and let us know how it turns out.
Old Sep 12, 2009 | 03:10 PM
jts_1979's Avatar
Default fix the stalling out on my 03 rincion
Thanks for the help. The petcock was gummed up and the throtle needed to be tinkered with. Hanks again.
Old Sep 12, 2009 | 04:20 PM
JeffinTD's Avatar
Running good then?
Happy to have been of some help.
Now that you are here, visit from time to time. It is a pretty nice forum.
Pehter
Oct 3, 2024 11:00 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
greg86hd
Sep 16, 2015 12:32 AM
Hw00d
Sep 10, 2015 08:53 AM
