swingarm bolt removal on 87 250R
Old Sep 4, 1999 | 08:31 PM
BrandonV's Avatar
My swingarm bolt is frozen. I've tried to heat it, beat it,and curse it. Nothing seems to help. Any ideas?
Thanks
Brandon
Old Sep 5, 1999 | 12:28 AM
Dill's Avatar
my friend had to cut his out with a cutting torch..sounds like your last option too...sorry to be the bearer of bad news
Pete Clyne, 1988 TRX250R http://www.parkrapids.net/pete
Old Sep 7, 1999 | 03:23 PM
philzie's Avatar
I had the same problem with my 350X. I took it to a machine shop and they used a hydraulic press to get it out.
Old Oct 12, 1999 | 11:51 PM
THEXOTIC1's Avatar
Get the old bandsaw out and cut the bolt between the motor monut bracket. I just did mine and replaced the bolt The bolt cost is $58 so hold on to the nut it will save you so money and you will also need new bushings because i m sure thay are locked to the swingarm bolt
Alex
Old Oct 13, 1999 | 07:43 AM
mp's Avatar
mp
I had this happen to me on a banshee try using WD40 and spraying in into the sides of the bolt, use a large hammer and hit it on the threaded side of the bolt, if it moves slightly spray WD40 into that crack then hit it back in the other direction, keep doing this back and forth and applying WD40, it took me a few hours but it did come out.
house1
Aug 9, 2015 10:49 PM
95wolv
Jul 21, 2015 12:25 PM
skeets44
Jul 17, 2015 01:04 PM
Desimation2k8
Jul 17, 2015 12:37 AM
Shifts
Jul 3, 2015 07:59 AM
