Fan and ES not working.
Old Feb 25, 2010 | 07:10 PM
tgardner1983's Avatar
Default Fan and ES not working.
I had an 04 350 rancher given to me. I put a new piston and rings and bored it .010 Tonight i put the motor back together, with new oil and filter. it fired right up but I noticed the fan was not working and I could not shift gears. I can shift the emergency shifter with a 12mm and it works. drove it around in 1st, it did drive good. so far i only have $80 in this bike. any suggestions on my fan or shifting. thank you
Old Feb 26, 2010 | 04:44 AM
HondaMechanic's Avatar
The fan will only come on when the bike is very hot .. We have customers that the fan only comes on a couple of times a year ..
As far as the ESP not working the gear position indicator should be flashing a code and you have to count the flashes ...
Here is the test for the fan ..
Old Feb 27, 2010 | 11:01 AM
I cheched the gear position flash. it flashed 5 times, which tells me its the ECU Driver Motor Circuit. Where would I find this and are there any recomendations on how to fix this?
Old Feb 27, 2010 | 03:17 PM
Here are the tests for code #5 ..
Old Feb 28, 2010 | 02:18 PM
I have figured out that I am a complete idiot. After looking all over this ATV i figured out that the shift motor is missing off of it. I can get one off of an early model rubicon, will it work or is it different from the rancher?
Old Feb 28, 2010 | 06:53 PM
hondafl350's Avatar
ok i have a 2000 honda trx 350 as whell and i have never seen the fan
come on so i replaced the thermister and it never mad a difrance. i am asuming the fan almost never comes on. i am scared that i might be runing it to hot is thair a coller temp thermastat u can buy?thanks for your time and help ps if i short the blue wire going to the thermster to ground the fan will come on.
Lucas Bohanan
Sep 29, 2015 01:16 AM
Steeldon
Sep 9, 2015 09:38 AM
John Reed
Sep 9, 2015 03:46 AM
soupcan
Aug 5, 2002 10:57 AM
RedRecon
Jul 19, 2002 11:20 PM
