89 Foreman TRX350d
Old Feb 27, 2010 | 05:50 PM
spareparts019's Avatar
Default 89 Foreman TRX350d
I just got one of these machines, which has a no start issue, which I have found to be a Timing issue, but my question is this. I removed the right side cover, which houses the alternator and pulse generator, and there was oil in there. Is that normal? I am not use to seeing oil in other ATV's where the alternator is.. Nothing mentioned in the manual? Is there a seal that may be bad? Any suggestions?
Old Feb 28, 2010 | 05:47 AM
HondaMechanic's Avatar
You must mean the left engine cover .. Yes the alternator runs in oil ...
Old Feb 28, 2010 | 12:28 PM
Yes, I meant the left engine cover.. Thanks for the reply.. I was worried I would have to replace a seal or something.. What should I look for with regards to the timing slipping? I was told that they were running it at extremely high rpms trying to pull another atv out of mud when it shut down. Can timing just slip. or should I be looking for something?
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
highwayman
Sep 19, 2015 12:59 PM
patrick.oc123
Sep 15, 2015 02:45 PM
