Header woes.....
Old Mar 16, 2010 | 07:40 PM
NMills's Avatar
Default Header woes.....
Hello all.. i have yet another problem... I changed out my exhaust... it does not seem to mate well with the engine... and i somehow crossthreaded on of the mounting bolts.... IT seems a bit loud from the front... like a leak... but i don't feel anything exhaust blowing... Does anyone thing it would be bad to weld the pipes to the engine... i'm not worried about later when or it i have to rebuild it... i'd deal with it then... but i want it so there are no leaks...
What's everyone thoughts???
Thanks...
Old Mar 20, 2010 | 06:52 AM
honkaw's Avatar
Welding your exhaust to your engine is a very bad idea!!!!!!!!!!!!!!!
Old Mar 21, 2010 | 07:21 PM
git_it_rag's Avatar
It would be hard to weld a steel pipe to an aluminum block. Drill out the holes one size bigger, tap them and use a heli coil. Get a heli coil kit for the size header bolt that you have and have somebody with that kind of experince give you a hand. It will be stronger than what it was before it stripped.
Bigtwin700
Sep 9, 2015 09:32 AM
Stillonit
Aug 5, 2015 07:46 PM
zach1106
Jul 31, 2015 01:55 AM
426ex
May 20, 2000 02:41 PM
