Just traded my Scrambler for a 400 ex. WOW!!
Old Mar 2, 2001 | 12:38 PM
Motorhead's Avatar
Well, there's basically two ways to check it. 1: Take the boot off the rear of the carb and look down inside to see if the throttle slide is all the way up at WOT (wide open throttle). The other way is to back the adjustment on the thumb throttle almost all the way out, then lightly hold the throttle at WOT. While holding it, screw the adjustment back in, and you'll be able to see the thumb lever move forward as you screw it in. Continue until you find the point where screwing in further doesn't move the throttle lever any further, and you've got it. Once you're done, the throttle should have about 1/4" of free play.
Old Mar 2, 2001 | 01:47 PM
snowshark's Avatar
Don't listen to the Quadfather. The right rider can make a 400ES go many places. I ride with a 400EX. The Raptor doesn't have much more ground clearance if any.
Old Mar 2, 2001 | 01:50 PM
400EX'r's Avatar
Now just buy the jet kit and remove the air box or drill it... That really wakes them up. Don't waste your money on any CDI boxes. You can trim the silencer on the stock pipe or buy a slip on. The factory head pipes are well sized for stock displacement.
Old Mar 2, 2001 | 03:51 PM
ex_master's Avatar
You just have to get used to riding a 2 wheel drive and you can go anywhere!
Old Mar 3, 2001 | 12:15 AM
  #15
max400ex's Avatar
Tell the polaris room that
400EX's are great
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
Matt123
Sep 29, 2015 01:29 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
