Please Help- 1984 ATC 125M Engine Case Question
Old May 14, 2010 | 07:50 AM
easygoin43's Avatar
Default Please Help- 1984 ATC 125M Engine Case Question
Hi,
New to these 3 wheelers and quads.
I aquired a great running and looking 125M, The bad- it will not shift. Took rt. cover off and found shift arm broke- no biggie I can weld.
But the worse thing is a small raised area that holds on the gearshift drum stopper broke off at the case.
I have seen pictures of the 110 engine case and it looks Identical.
I know the bore in cyl. and piston is probably different- but all I wanted was the Rt. side case and re-use my good running engine.
Can I use the 110 case or any other ideas?
Thanks in advance for any advice..
Chris
Old May 21, 2010 | 07:02 AM
honkaw's Avatar
go to cyclepartsnation.com and check the part numbers
hugemoth
Jul 20, 2020 03:28 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
MNatv89
Jul 7, 2015 11:36 AM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
