Honda 250EX front brake replaced, one drags...
Old May 21, 2010 | 03:36 PM
unclejemima's Avatar
Default Honda 250EX front brake replaced, one drags...
I changed the front brake pads on my 250EX a few days ago, and the procedure went well. I used the EBC severe duty pads that are supposed to last longer than regular.
When doing the change, the one caliper would not open as far as the other when I compressed the piston, but it still opened far enough to allow the pads to clear the disc rotor.
The other side went perfect.
So now I have one wheel that barely spins and the other spins perfect. I did the same procedure for both. Any idea what to do?
I could just let the one pad wear down by driving it(as it is dragging) so it becomes even with the other one, or is there something else I can do?
Someone told me that I should grind the one pad slightly down, but this does not sound like a good idea either?
Any advice?
Thanks,
Old May 21, 2010 | 04:42 PM
sdm111's Avatar
2 strokes or 4
Sounds like a caliper is sticking. Take it off take the pads out squeeze the brake to let the piston come out a little and see if there's rust on it, if so pop out the piston out watersand it with some 600 grit put it back in without messing up the o ring and you should be good to go.
Old May 21, 2010 | 05:19 PM
Sounds good! I'll give it a try!
Thanks,
AK47KID
Jul 23, 2015 09:21 PM
Jake55
Jun 29, 2015 06:43 AM
scaldwellk
Jun 19, 2015 05:08 PM
gdmclnh
Jun 13, 2015 05:32 PM
lovinhonda
Jan 25, 2000 09:17 PM
