Want more speed trx 400ex
Old May 24, 2010 | 03:20 AM
DJTSUNAMI's Avatar
Thumbs up Want more speed trx 400ex
Recently got my quad jetted n k&n air filter....still want more speed tho...top end speed any suggestions without a big bore kit or messin with the motor,thank you
Old May 24, 2010 | 07:28 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
The only way you are going to gain top speed is to change the gearing. Different sprockets. Bigger front/Smaller back.
If you haven't put a exhaust on you should. It will be the biggest gain for your $, then rejet. It will really wake the thing up.
Old May 24, 2010 | 12:32 PM
DJTSUNAMI's Avatar
SORRY POSTED THIS LATE WAS TIRED...HAVE A SLIP ON FMF EXHAUST ALREADY....WHICH SPROKET GIVES U TOP END FRONT OR BACK..CUZ IF iDO BOTH IT WOULD BE THE SAME AS WHATS DONE NOW CORRECT? BUT IS THAT THE ONLY OPTION MY SPROKET...WHAT KIND DO iWANT CANN YOU LINK ME TO THE RIGHT ONE THANK YOU
Old May 24, 2010 | 12:47 PM
Koopa's Avatar
Bigger front or smaller back. Go to motosport.com or denniskirk.com put in your quad info. Find what the stock tooth count is on yours (15? maybe) and find one a size bigger.
Warning though. You lose bottom end power to gain top end speed. That means slower off the line. I can speak with experience that hill climbs on a piped EX are much less fun when geared higher sprocket.
Old May 24, 2010 | 02:30 PM
DJTSUNAMI's Avatar
DULY NOTED...iDONT DO TO MANY BIG HILL CLIMBS BUT WHEN iDO USUALLY GEAR IT INTO 2ND AND OFF iGO...THATS SOMETHING TO THINK ABOUT IF ITS GONNA BOG IN 2ND OFF THE LINE iMAY JUST KEEP IT THE WAY IT IS AND WORK ON THE COSMETIC SIDE OF IT
Old May 24, 2010 | 02:35 PM
Koopa's Avatar
My 400EX had 22" tires which is effectively the same as changing the front sprocket 1 tooth. When I dropped a tooth to compensate it was the best money I spent on the quad. No more unexpected stalling or bogging at the top of a hill or working through a creek. It's
Old May 24, 2010 | 02:41 PM
DJTSUNAMI's Avatar
WOULDNT THE SPROKET BE CHEAPER THAN A SET OF TIRES THOUGH? AND WITH MY QUAD iWANT PERFORMANCE BUT ALSO LOOKS,DONT WANT NON MATCHING TIRES..
Old May 24, 2010 | 02:44 PM
Koopa's Avatar
I mean when I purchased mine I had 22" tires which makes it higher geared. I hated it and went with a smaller front sprocket to give less top end/more bottom end.
Sprockets are cheap and easy to install. For the price you could play with it to see what you like.
Old May 24, 2010 | 02:46 PM
DJTSUNAMI's Avatar
Thank you for your help
Pehter
Oct 3, 2024 11:00 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
