Honda 01 TRX450ES won't idle
Old Jun 5, 2010 | 08:49 PM
Pension 139's Avatar
Default Honda 01 TRX450ES won't idle
My 450ES won't idle. It starts with the choke, but when you go to idle, it idles then a loud ping occurs and it shuts down. It runs good above idle speed. I've checked the carb, I was going to check the timing chain. Any ideas?
Old Jun 10, 2010 | 08:02 PM
stuartshomepc's Avatar
More often than not it's a plugged low speed jet. It is such a small hole that they are hard to clean. At idle it's the only path for fuel to flow. Since you say that it runs fine off idle I would re-check the low speed jet.
Old Jun 19, 2010 | 09:29 PM
04honda's Avatar
I had the exact same problem on my 2003 450ES and it took me like 4-5 time of cleaning the carb to finally see that I was over looking a piece of dirt in a jet. After I cleaned it it runs like a champ! Get a needle or something the same size as the jet holes and run it through every hole to make sure they are clean!
hugemoth
Jul 20, 2020 03:28 AM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
hondarider1234
Jul 21, 2015 11:53 PM
ranvette
Jul 12, 2015 06:34 AM
MNatv89
Jul 7, 2015 11:36 AM
