2003 300 ex wont start
Old Jun 24, 2010 | 09:46 PM
olivere's Avatar
Default 2003 300 ex wont start
Please help! My 300 ex has been sitting for a while. The batterey seems to hold a charge(lights work) but all I get is clicking.
Any thoughts?
The few times I have gotten is to run it stalls out quickly. Could it be bad gas?
Old Jun 26, 2010 | 01:19 PM
Beastly 3hundo's Avatar
most likely, annother thing that might help alot with starting is getting the valves adjusted back into spec. maybe bump starting will work....
Old Jun 26, 2010 | 07:21 PM
Triggerfreak's Avatar
When mine did this it was bad ground connections.Try cleaning all the connections to the battery and the ground to the chassis.Also the battery micht just be too weak to roll it over.
Old Jun 27, 2010 | 01:23 AM
try the 2 wires going into the sillonoid... those come loose very often
Old Jun 27, 2010 | 01:52 PM
olivere's Avatar
I tried jumping it and it started with full choke and ran for about 7-8 mins then stalled. After that it would not start again. When I spray some starting fluid it will start and imediatley stall. The wiring seems fine.
Any suggestions for next step?
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
Jake55
Jun 29, 2015 06:43 AM
1000gade
May 27, 2015 12:37 PM
ragewraps
May 26, 2015 03:14 PM
