98 honda trx450es 4x4
Old Jul 7, 2010 | 10:04 AM
cdi's Avatar
cdi
Default 98 honda trx450es 4x4
Honda cranks and then you can drive around but if you stop and let idle it dies and I have to wait 15 to 30 minutes before I can crank it back up. The motor turns over but will not crank during this time. The carbs have been cleaned but it still happens. It is in a shop to be repaired now and the guy says it has to have some electrical parts and the price is 600.00 to repair. Does anybody have any suggestions????????
Thanks,
Cdi
Old Jul 7, 2010 | 11:22 AM
ddrumman2004's Avatar
Most likely an electrical problem as it sounds like something is over heating and then it shuts down. After it cools off, it starts.
I have seen this happen with older points type ignition systems where the condenser would overheat causing the points to not "fire" and ignition coils will do this when they get older.
With newer solid state ignition systems....like a CDI box.....they can do the same thing. In fact, heat is a big enemy for any solid state system, be it ignition or a computer.
Old Jul 8, 2010 | 06:10 AM
cdi's Avatar
cdi
Thanks for your comments
Old Jul 8, 2010 | 08:54 AM
TLC's Avatar
TLC
CDI system still have a ignition coil. Thats how those things die,they heat up and quit,once they cool off they work again.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
