84 trx200 no spark
Old Jul 19, 2010 | 12:25 AM
sectlandscaping's Avatar
Default 84 trx200 no spark
I picked up a project bike. The damage, front brake lines cut, no seat or rear plastics, two flat rear tires, missing rectifier, missing reverse/neutral light. I have a newer ebay starter that came with it and the battery is on the charger.
First thing I did is check compression after 5 pulls it was 100 psi. Then spark which I didnt have. Tried different plug same result. The ignition coil looks like it was replaced but cant be working or the problem is somewhere else.
I do have a multimeter but dont no what to check when the battery is in.
Old Jul 23, 2010 | 06:55 AM
honkaw's Avatar
It probly is your coil , but if you take your coil to a dealer they can check it for you.
Old Jul 23, 2010 | 10:37 AM
budedm's Avatar
Does it have a CDI box?
Old Jul 23, 2010 | 07:42 PM
i tried a new coil and the new and old one test good. still no spark. It does have a cdi and i cant find any way to test besides swapping.
Old Jul 29, 2010 | 11:44 AM
williams8899's Avatar
Used Auto Parts
Used Car Parts
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
