06 Rancher AT won't shift flashes code 6
Old Jul 26, 2010 | 01:58 PM
skofflaw's Avatar
Default 06 Rancher AT won't shift flashes code 6
The bike had shifting issues, after installing a new Angle Sensor it won't shift out of low gear and reverse sputters like in a default mode. I found where Bowhunter20 had the same problem with his 04 Rancher but never I found his solution. In his post the service manual said to perform "initial settings" on the ECM. Is this what I need and if so how is it done. Thanks alot.
Old Jul 26, 2010 | 06:03 PM
polymite's Avatar
I cannot over stress the importance of water proofing ALL ele. connections....
If it has a plug please apply silicon grease to ALL ele. connections.
Jesus, I am starting to sound like reconrancher..... complaning about ele. shift ranchers...
They are not bad at all.. mine has a lot more wet miles than dry miles and still works great never replaced a angle sensor or any thing else.. now if i could just get some horse power out of it I would be tickeled pink.
2004 honda rancher 850 mi. close to 320 hrs do the math it has been in a lot of mud and water.... 27"vampires and dyno jet jets clipped carb. spring snorkeled and vented to the max. never died in water but has been towed and winched a bunch
also check out trade bit.com for a $5.00 honda shop manual for your bike.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
exmotocrosser
Sep 26, 2015 08:18 AM
Clint Russell
Sep 25, 2015 03:20 PM
Sw00p
Sep 24, 2015 02:50 PM
