300ex getting to much gas
Old Sep 1, 2010 | 06:59 PM
hondarider123's Avatar
Default 300ex getting to much gas
i have a 95 300ex and it gets to much gas i put all new jets seals gaskets and float and it still isnt working right i adjusted the air and fuel mixture and it doesnt help. anyone got any ideas? i can turn the fuel off and right before the fuel runs out it works perfect
Old Sep 1, 2010 | 07:15 PM
budedm's Avatar
You sure it's "too much gas" or is it "not enough air"? An engine needs both in the correct amount to run good. When you turn the gas off, the engine runs until the last of it but just before it runs out, it has very little gas in the carb going into the engine. At that point, the ratio of air to gas goes up. That's whay I'm asking if you're sure it's getting enough air.
Old Sep 1, 2010 | 07:31 PM
yeah true but ive tried everything it dont even have a filter on it and when i do put the filter on it runs worse it just seems like to me its getting to much gas ive rebilt the whole carb it got better but its still off just a little bit
Old Sep 1, 2010 | 07:54 PM
jasonn20's Avatar
Are you running it with the choke ON or OFF..?? It probably will not idle till it is completely warmed up and the choke off. Make sure the carb is seated properly into the head extension and the clamp is snugged up well.
Old Sep 1, 2010 | 08:06 PM
im running it with the choke off and it will idle it just acts like it is skipping when i have it full throttle
Old Sep 1, 2010 | 08:19 PM
budedm's Avatar
Is it stock? Any mods?
Old Sep 1, 2010 | 09:01 PM
its bored 80 over with a weisco piston and clutch kit
Old Sep 3, 2010 | 05:00 PM
Bigborekit's Avatar
your main jet is too small . What color is your plug ? what size main jet are you running?
Old Sep 4, 2010 | 03:09 PM
im putting a dynojet kit in it so it should run fine now
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
