How do I keep my grips on?
Old Mar 10, 2001 | 10:56 PM
norcalatver's Avatar
I cannot seem to keep my Oury grips glued on to my Renthal bars. I have used 3 different brands of grip glue and none seem to work. Any suggestions would be awesome. Thanks.
Old Mar 10, 2001 | 11:20 PM
TheQuadfather's Avatar
Did you clean the bars with alcohol first? I don't mean Bud Lite either.
Old Mar 10, 2001 | 11:22 PM
94DGblaster's Avatar
use some hair spray
Old Mar 10, 2001 | 11:32 PM
FireBug's Avatar
I wrapped tape around my bars and used my spit to slide them on and they have stayed.
Old Mar 11, 2001 | 12:17 AM
TRAIL's Avatar
i used to use hair spray on my bicycle and then it takes 3 days to dry,wet them with gas,slip then on ,in about 5 minutes or less they r stuck,i have never had any problems with mine!
Old Mar 11, 2001 | 01:17 AM
hot_shoe_cv's Avatar
I too have used hair spray, the non-aerosol type, for many years both in competition as well as on play bikes & quads, I also use safety wire for additional insurance. Just be sure the surface is clean & smooth, theb spray both the bar ends & inside the grips liberally before installing, and don't touch them for at least 24 hours.
Old Mar 11, 2001 | 03:53 AM
ONEBAD440's Avatar
3M makes some really good stuff. It's grip glue and the tube I got was $12.00 but I use it for about anything. Never had a set of grips come loose since.
Old Mar 11, 2001 | 04:07 PM
JRM's Avatar
JRM
my XR's grips have been giveing me trouble for years, Iv tryed all the above and they just turn to slime on the inside and become loose. I got mad and used PCV pipe cement, that worked!
Old Mar 11, 2001 | 05:02 PM
derekhonda's Avatar
The best thing that I have learned is it takes time. I just put some hairspray (or spray paint works well also) straight on the handlebars, and then slide the girps on and let them dry. I only let it dry for about 24 hours once and it slid off the next day during riding. Thats no fun....swingen your quad around a turn and have your whole hand slide off. So anyway, I redid it that night and let it dry for 3 Days. Havnt failed me yet.
* Also side note, How do you like your grips, i got ourys too, i think they are sweet.
Old Mar 11, 2001 | 07:25 PM
Zorro's Avatar
When I changed mine, I simply put some soapy water, "dry it" with a hairdryer, and put some safety wire around them. They haven't moved since.
