horrible smoking after rebuild
Old Mar 24, 2011 | 01:52 PM
isthatstatic's Avatar
i micd the jug at home then took it to a machine shop and have it re checked measured out to 86 on the nose, then i went to the honda dealer here in town and had them match me a piston and a set of rings online from their carrier then they ordered them for me.
Old Mar 24, 2011 | 02:14 PM
roadiestar's Avatar
what about the head did you have it checked
Old Mar 24, 2011 | 02:18 PM
I assumed so since it had a machine shop tag on it from being ported and cleaned
Old Mar 24, 2011 | 03:09 PM
roadiestar's Avatar
That don't mean anything the guides could be shot or the seal real bad.
Old Mar 24, 2011 | 06:43 PM
  #15
yeah true. I'm going to check the guides tomarrow and report back to you
Old Mar 25, 2011 | 07:36 PM
  #16
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Make sure you put the gaps in the oil rings (not compression rings) 180º apart, best to line up the gaps over either end of the wrist pin.
Old Mar 26, 2011 | 08:04 AM
  #17
95wolv's Avatar
One other thing to check is the ring gap, I had a new push mower ( I know, not an atv) and it smoked and used oil like crazy, but i kept using it all summer. after putting it away for the fall, I decided to pull it apart and see what was going on. I was supposed to have something like .008 ring gap with the ring in the bore, turned out I had over .060, so the oil was shooting up into the combustion chamber and out the pipe. Ran good, but smoked like a rich 2 stroke, and had to add oil almost every other time I mowed. It was a cheap Walmart mower, so I never took it back, in case you wondered !!
EIF
Apr 20, 2017 07:15 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
