HELP 07 Rincon Wont Start
Well i took the gas tank off and inspected the hose got it stright but still wont start
Its usely never something that simple. So i guess i will put it in the shop tuesday and see if they can figer out what it is. It run fine before i did the valves.
im in north west arkansas eastern oklahoma area
also i did a expement when i had the gas tank off i blow into the vent hose on top and i was able to blow through it and gas came out the feed hose. but when i put the tank on and put gas in it i tried blowing through it and i could'nt do it like if it was clogged or something.
#16
well i went today to see what they found out about it and they havent had much time to check it but they did say that it wasnt sparking right like its nothing getting enough spark and they belive thats why it wont start.
#17
Let us know. I hope I didn't send you on a wild goose chase, but with since it ran briefly after the valve adjust and then quit, gas not getting to the sub-tank (or air not being allowed to escape) appeared to be the most logical place to start.
#18
Got my four wheeler back today! i got screwed big time all it was was a dam fuel filter
coasted me $13 for the filter $4 in gas $6 in plugs and like $9 for wires then $135 just for labor. I even thought it might be a fuel filter but the rincon guide didn't say much about it havening one and i didn't see any on there to replace my self. This should be under general maintenance such as everything else
