DMC Full Exhaust on 400ex
Old Mar 13, 2001 | 01:24 PM
ME400EX's Avatar
Going to install the DMC full exhaust and I was wondering what everyone else uses for a main jet? I'm not going to buy a K&N power kit or anything like that. I just want to put the system on, change the main and ride. Oh, and you DMC owners, have you been happy with it?
Old Mar 13, 2001 | 02:10 PM
Neodeus's Avatar
heyyyyy does dmc stand for delorean motor company!?
Old Mar 13, 2001 | 04:11 PM
SuLlY400's Avatar
the dmc was great for me...... it pulls so much harder through every gear... and it also works great with healily modded engines... i have a 165 but i am getting a 160... its a lil rich... go with 158 or 160.. the 400 needs to run lean to run right... you cant tell proper jetting my plug color on the 400... 158 or 160 would be great..hope i helped..
01 400EX yellow, DMC Double Barrel Full Exhaust.
Old Mar 14, 2001 | 12:17 AM
K_Fulk's Avatar
I run a 155 main and 40 pilot jet and raised the needle one notch and played with the airscrew to get it right.I like the pipe it pulls hard. The only problem i had was it melted a spot on my boots. So i got some header wrap from jegs. The more heat you keep in the pipe the more it flows.
Old Mar 14, 2001 | 01:29 PM
ME400EX's Avatar
Does the DMC stick out alot more than the stocker? Can't get a guard for the pipe?
Old Mar 15, 2001 | 12:42 AM
K_Fulk's Avatar
The pipe dosent stick out that far but its not coverd by anything.You can either get some header wrap like i did or James Lucky sells some heat shields you can clamp on.
STLyamwar
Jul 25, 2020 04:44 AM
Huntingdeer
Aug 23, 2015 12:06 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
