starts but don't think it's compressing
Old Aug 15, 2011 | 09:28 PM
chad12's Avatar
Default starts but don't think it's compressing
does this mean the connecting rod is snapped? honda 2002 400ex. sorry if i sound like a complete idiot but i'm new to this. anything else it could be? thanks for the help
Old Aug 15, 2011 | 10:20 PM
irinman2424's Avatar
if not getting compression could be many things (piston has a hole, rings are bad, gasket, weak spark etc) if its the connecting rod it wont start at all and when you turn it over there should be a loud knocking sound
Old Aug 15, 2011 | 10:47 PM
mouse4x4's Avatar
It prolly has a worn top end it wouldn't run at all with a hole in the piston or a broke rod if it starts but lacks power or smokess bad it is a worn top end if it is nosiey then. Timing chain might have jumped time it is a couple things 400 an 300 ex are know for but they run for ever
Old Aug 17, 2011 | 09:20 AM
chad12's Avatar
thanks for the info.
Old Aug 17, 2011 | 01:51 PM
mouse4x4's Avatar
No problem let us know what u find out
Old Aug 18, 2011 | 08:25 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
If it has no compression, it wouldn't even start.
Old Aug 19, 2011 | 10:35 AM
depents on the size I have seen 2 cycle that would start but had little compression and had a pinhole in the piston where someone put straight gas instead of mixing it didnt run it too long and burned a pinhole in the piston
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
joshuafromny
Jun 22, 2015 05:30 PM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
