what to buy
Old Sep 8, 2011 | 12:21 PM
Originally Posted by faruquehabib
the full name for the rubicon is "Honda Foreman Rubicon", so yes, it is a variant of the Foreman. However, when the foreman changed in 2012, the rubicon did not, so for now, there are some differences other than engine and tranny. the new foreman has a single shock in the rear and no low range. the rubicon still has dual shocks in the rear and has a low range. you can also switch to ESP mode on the rubicon, which acts like a 5 speed manual, "shifting" using the handlebar shift like a foreman / rancher / recon ES. the "gears" are preset ratio's in the hydrostatic transmission.
i have a 2009 rubicon, 2010 rancher, and a 2005 polaris ATP (the predecessor to the sportsman X2). the polaris has more power and a softer seat. the honda wins in everything else. i ride the ATP for an hour, then switch to my rubi, and the difference is night and day. granted, the rubi is 4 years newer and has power steering, but the overall craftsmanship and ergonomics are superior on the honda in my opinion. i do use both the rubi and polaris for work, and both pull their weight in that department.
ride them and do your research. good luck!
The ATP is a work beast. It's not a great comparison to the regular Sportsman. It has a 400 lb. rated rear with a solid axle and two shock/springs. Was kind of a mistake for us to buy one when my son had one. Brutal ride. The IRS equipped Sportsman is one of the nicest rides out there. I have a bad disk and even with a 400 lb. rated rear the X2 isn't bad on my back unless I do something really heinous like dropping off a 2 foot drop without enough speed to get a smooth landing.
Old Sep 8, 2011 | 09:01 PM
railroad mike's Avatar
Default Thank you
thanks everyone for your advice and the information. I bought a 2012 honda foreman i hope i made the right choice.
Old Sep 8, 2011 | 09:05 PM
angler's Avatar
Nice choice, you will not be disappointed.
Old Sep 9, 2011 | 07:26 AM
Congratulations. Honda makes great quads.
Old Sep 9, 2011 | 08:07 AM
  #15
Specta's Avatar
congrats on your new Honda.
Now all you need is a nice set of wheels and tires.
I like these from STI.
Old Sep 15, 2011 | 01:48 PM
  #16
redhonda24's Avatar
The Rubicon does have slightly more hps than a foreman, I think something like 7 more
Old Sep 15, 2011 | 02:03 PM
  #17
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
you're asking people in a honda forum if you should buy a honda or a polaris???
I'd go with the polaris personally- I'd rather have an IRS, a cvt clutch and a locking front diff...
Old Sep 15, 2011 | 02:04 PM
  #18
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
ooops- I guess I was a little late to the party.
congrats on the new quad
