300ex flywheel turning but cam not moving
I bought a project 2002 300ex that would not run. My first suspicion was that it wasn't timed right so when I went to time it I noticed I could turn the flywheel but the cam wouldn't turn with it. The cam does rotate very freely on it's own tho. There's not much slack in the cam chain so I don't think it slipped off the lower gear. Possibly the gear is stripped completely or is there something else that could cause this? Thanks for all the help!
What all is involved in changing the lower gear if that is in fact the problem? Is that lower gear part of the crankshaft?
Usually you just have to pry the little key out and possibly there will be a reverse threaded nut holding the gear in place. With the $$ you will save by doing this yourself, it is a good idea to grab a shop manual for it!
The root of the problem wasn't as bad as I expected. The timing chain slipped off the sprocket. I put it back on and the cylinder, piston and valves all looked good so I fired her up and she runs great.
