Honda TRX 125 Spark Issues -Help Please-
Old Mar 24, 2012 | 11:27 AM
Malcolm Reid's Avatar
Unhappy Honda TRX 125 Spark Issues -Help Please-
I was riding my bike one day and it started to slowly lose power until it cut out and now it appears it has no spark! Ive read the other threads on this issue and have tried the following changed the coil from a mtx125 i had still didn't work, changed the cdi from mtx as well still no spark checked round the wires for and grounding on frame, tried different ignition still noting and also checked kill switch and it seems ok! Now i no the coil etc from the mtx were ok but could it be that the parts from the mtx are not compatible! Any help on this issue would be greatly appreciated!
Old Mar 24, 2012 | 11:39 AM
Jaster94's Avatar
you may have done this but not stated this, but did you change the spark plug? losing power? i presume just laboring to run rather than bogging down? any smoke? what color was the end of the plug? i try to go to the easier things before i move on to the more complex/expensive items. do you have any multimeter measurements at the coil wire or CDI? trigger output?
Old Mar 24, 2012 | 11:50 AM
It slowly just started to lose revs and died out, then wouldn't start, the plug was a little black but was pretty clean. I tried the spark plug from my lawn mower which is a good one and it has no spark either! Im waiting for my brother in law to come over with his meter so i can take readings from coil etc! Thanks for the reply!
Old Apr 2, 2012 | 01:22 AM
Huge29's Avatar
I had similar issue on the same model and there was a short near the headlight. It sparked when the plastics were off, but once I put it back together no spark, much less fun the second time.
Land_shark1
Jul 10, 2015 12:53 AM
Ty Speece
Jul 2, 2015 04:59 PM
jag6510
Jun 15, 2015 05:59 PM
Joe04785
Jun 15, 2015 03:12 AM
lovinhonda
Jan 25, 2000 09:17 PM
