2007 TRX420FM - won't start
Old Apr 1, 2012 | 08:43 PM
mrtappan's Avatar
Default 2007 TRX420FM - won't start
2007 TRX420FM that won't start.
No FI light codes, all fuses good, and gas is good.
Temperature is 80*+ during tests.
Engine simply turns over during attempted starts. No backfires, no attempts to start. Compression is good. Wondering what could be wrong that would cause an engine getting spark, gas, and air not to start?
Not overly familiar with EFI four wheelers so any avenue to check would be helpful. Any common items on this model that typical go bad and would cause this issue?
Items checked and the result:
Fuel pump - primes correctly, pumps as engine is turned over
Spark plug - sparks when engine turned over, have not tried a new plug though
Fuel filter - clear
Fuel lines - clear
Fuel injector - sprays correctly with engine turning over
Air filter - not installed during the testing process, so not an issue
Thanks in advance for any help.
-Shannon
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
bogie ben
May 30, 2015 04:10 PM
1000gade
May 27, 2015 12:37 PM
Icedevice
May 25, 2015 08:38 AM
MrElussive
Nov 19, 2000 01:51 AM
