Recon Ft. brake upgrade question? 250ex brake swap
Old May 14, 2012 | 01:55 AM
whitfield's Avatar
Default Recon Ft. brake upgrade question? 250ex brake swap
Just refurbished a beat down 2006 Recon for my Daughter.
These Front brakes SUCK... My 98 Recon has good working drum front brakes, so I know what to do to make these work OK too.
BUT
as I am preparing to rebuild the (BAD) front master cylinder...
What are the odds of swapping out the Honda 250EX front spindle and disk brake assembly (master / caliper / rotor / ect..) with the Recon. Both bikes are very similar???? Recon front brakes have long been a sore subject for most.
Old May 14, 2012 | 04:42 AM
95wolv's Avatar
The 250EX is basically a Recon with sport plastic, I would take a quick look at one to compare the a arm set up and spindle mounting, but sounds like it should be pretty doable with a donor quad for parts..........eBay, here we come !!
toonces
Oct 16, 2019 12:11 PM
DeFox500
Jul 26, 2015 06:32 PM
hondarider1234
Jul 21, 2015 11:53 PM
cSchwartz
Jul 9, 2015 02:40 PM
MNatv89
Jul 7, 2015 11:36 AM
