how to get my timing chain off trx300fw
Old Jul 18, 2012 | 12:24 AM
jclark2894's Avatar
Default how to get my timing chain off trx300fw
My motor locked up on me and I can't figure out how to get the cam and timing chain off.
Old Jul 18, 2012 | 01:31 PM
jclark2894's Avatar
Anyone
Old Jul 18, 2012 | 10:56 PM
Cummins Driver's Avatar
Pull the valve cover off, then take the bolts(2 i think) out that hold the cam chain gear to the cam. Take the automatic tensioner off the side of the head, then pull the gear off the cam drop it down slightly to take tension off the chain so you can remove it from the gear, then pull the gear and cam out. It would be easiest to do this with the engine at top dead center.
If the timing chain isnt real loose or bound up, then you'll probably need to look elsewhere for your problem though.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
