07 250ex de-acell popping
Old 08-09-2012, 08:31 PM
durs845's Avatar
Default 07 250ex de-acell popping
Hows everyone doing ? Im new to this forum , so ill give you a little info about myself then move onto my question . My name is Kris im 30 years old , i live in Dutchess county NY .In my toy garage i have 05 Suzuki Z 400 , 07 Honda 250EX , 91 Yamaha YFM100 , & 2 Kazuma 90cc Mini Falcon's . So on to the question : I put a new slip on muffler on my girls 250ex now on decel it starts popping/backfireing any quick fix's besides paying to rejet ? Thank you
Old 08-10-2012, 09:59 AM
Doctorturbo's Avatar
GOT BOOST!
First make sure you have no air leaks from the head to the end of the pipe. If you have a leak it will suck O2 and that will mix with the left over gas in the pipe and give you a pop.
If you have no leaks then open up the fuel/air screw on the carb a half a turn at a time until the pop goes away. If this does not cure it you will have to jet up a tiny bit.
Old 08-10-2012, 11:50 AM
durs845's Avatar
thank you for the info , i do believe i have a slight leak in between the front pipe & the slip on , ill have to look into sealing this up better . thanks again
Old 08-10-2012, 02:27 PM
budedm's Avatar
You may be running lean. That's bad and can cause piston meltdown. Bigger jet.
Old 08-10-2012, 07:13 PM
durs845's Avatar
so best bet would be to pay to have rejetted i quess
Old 08-12-2012, 06:28 PM
budedm's Avatar
Pay??? No way. It's cheap and easy. Buy 4 or 5 in different sizes (a few bucks each) and try them one size up each time.
Old 08-12-2012, 08:21 PM
durs845's Avatar
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
Alex G.
09-11-2017 11:38 PM
Scooter's Shop
23
10-22-2015 07:04 PM
Dunes and Dune Machines
09-29-2015 09:35 AM
r1pilot83
09-27-2015 07:38 PM
Quick Reply: 07 250ex de-acell popping
