2001 Honda Rubicon
Old Aug 10, 2012 | 10:41 AM
njjane's Avatar
Default 2001 Honda Rubicon
What does the dial that has ESP, D1 & D2 do? What should I have it set on if I want to have automatic gear shift and do nothing?
Old Aug 10, 2012 | 03:24 PM
TLC's Avatar
TLC
I believe ESP is no shift Automatic mode, and D1 is shift mode low range and D2 is high range shift mode.
Old Aug 10, 2012 | 10:03 PM
papahouse's Avatar
ESP is electronic push button shift, D! is auto LOW and D2 id Auto HIGH
Old Sep 9, 2012 | 10:45 PM
Specta's Avatar
ESP is 5 pre-selected swash plate angles so you can "shift gears". (there are no gears in the trans, only in the sub-trans)
D1 - keeps the engine rpms in the peak hp band
D2 - keeps the rpms in the peak torque band
Honda's original idea behind D2 was for when you started out on slippery surfaces you were less likely to spin the tires.
Honda has since eliminated D2. I use it a lot when driving on smooth level trails because the rpms are lower than the are in D1.
Hunter100us
Oct 7, 2015 11:46 PM
bigred20653
Aug 31, 2015 12:41 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
maxjung
Jul 14, 2015 03:10 AM
