1986 Honda Fourtrax 4x4 Raddling noise
Old Sep 16, 2012 | 11:53 AM
Honda 3Fitty's Avatar
Default 1986 Honda Fourtrax 4x4 Raddling noise
Hey everyone I have a 86 honda fourtrax 359 4x4 and when I drive it over 30 KPH and let off the gas I start to hear a REALLY LOUD rattling/ crunching noise comming from what seems to be where the shaft goes into the motor or up in the front. The bike doesht lurch or jump but it does gring gears somtimes if that helps?
I also have a 86 Honda 250 that is RWD and it does the same thing but shifts nicly, it sounds like the U joint is hitting the sides of the tube that it sits in but all have good U joints from what Ive seen?
Any Ideas Would Be Appreciated?
Old Sep 21, 2012 | 06:19 AM
atvMANIAC666's Avatar
check frame, alighment, then shocks then alighment on the shaft, andd connectors, could have a gear out of posistion if it inly happenes when you let off gas. ? break the case aans check the gears for broken tooth or abnormal wwear. hope that helps i have t 86 hondas and ive done all that, a good hard ride can explain all the things your saying. at least how i ridr those things.
1986Vmax540
Jul 9, 2021 09:53 PM
Divergent12
Dec 30, 2017 08:33 PM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
