Tire Size...
Also front tires tend to run undersize in my experience. Especially dunlops.
20's on back and 23's on front. If I had it to do again, I would have 18's on the back. Ground clearance in the back is overrated.
Here is a 250ex with 22's on back and front. See how much smaller the fronts look? I think this setup looks gay, but with shaft drive I was forced into it because I wanted a higher top speed. It goes faster, but it take a much longer time getting there and the clutch slips a lot more. Also lost the ability to slide. I'm not sure the higher top speed is worth all the problems of a 22 inch tire.
some tires measure differant than others, the ones on randy's quad look pretty good. But all in all i say 1" taller up front is all you need. I've never had a problem going down steep and steep hills, just keep on the rear brake. We have rocks and roots on the trails, rocks anywhere from the size of 2 fists, all the way up, and lots of them!
Sep 30, 2015 01:37 AM
