400ex pivot bolt
Old May 1, 2013 | 08:24 AM
budedm's Avatar
Go rent an air impact gun. Or maybe an auto parts store will lend you one.
Old May 2, 2013 | 12:13 PM
Neverdone's Avatar
There is nothing to put the imapct gun on, I cut the head off the bolt..... I think I am going to just cut it and be done.
Old May 2, 2013 | 12:16 PM
budedm's Avatar
Sorry. I meant to say "impact hammer". Go rent one and it will drive the bolt out.
Old May 2, 2013 | 08:44 PM
jgar's Avatar
Cutting the bolt is the answer.
Old May 3, 2013 | 09:36 PM
  #15
LT80's Avatar
LT80 Expert
Use the air chisle (air hammer) and hit the end of the bolt to push it thru.
I looked back and I see you posted that you tried inbetween the swingarm/frame which will never work.
Old May 6, 2013 | 11:29 AM
  #16
Neverdone's Avatar
After much frustration, agrevation, cussing and destroying things, I got it out. Beating on the bolt was useless, I had to cut it. What I did was cut the bolt on the right side between the motor and swing arm. What I did was first a little bit at a time and turn the bolt with a pair of pliers on the nut side and cut some more. Eventually cut it all the way off. Then I did the same thing again cutting out about 3/4" from the bolt. Then I slid the motor over and cut the bolt on the left side of the motor the same way. To cut it, I used a straight grinder with a 3" cut off wheel. Only damage was to the swinger, burnt the rubber pads a little bit.
With the motor out, I was then able to knock the left side of the bolt in to free up the swing arm. The right side of the bolt was another story. To get that out of the swinger I had to beat it outwards. When it finally came out I found out why it wouldn't move any more.
I don't know if the crack there was from me pounding on it or if that was part of the reason it was stuck. In any case it is out and I am ready to move on.
Side note, the sleeves are what I think was keeping it from moving, everything else seemed fine. Putting it back together, never seez will be my best friend at this step.
Old Jun 7, 2013 | 05:56 AM
  #17
Neverdone's Avatar
New bolt installed, coated the whole thing with never seize. Hopefully that bolt wont ever be an issue again!!!
Old Jun 7, 2013 | 06:29 AM
  #18
budedm's Avatar
The anti-seize is a great thing to do, but you should mix it with waterproof grease. And if you haven't put the swing arm completely on yet, do this: Put anti-seize/grease on the bolt and run it into the swing arm. Then pull it out, put anti-seize/grease on it again and run it through the other side. Then assemble. The reason is because the anti-sieze/grease (or anything you put on a bolt in a situation like this) gets wiped off as you insert the bolt. So, the far end of the hole remains dry. It's very difficult to get anything to the center though. The best way would be to use a dowel of a somewhat smaller diameter and coat it with NS and run it through. Just my 2 cents.
Old Jun 7, 2013 | 08:23 AM
  #19
LT80's Avatar
LT80 Expert
I've never been impressed w/never sieze. I use Fluid Film on everything now.
I'd recommend taking that bolt out and re lube every 6 months.
Old Jun 7, 2013 | 11:51 AM
  #20
Neverdone's Avatar
with how much I tinker I am sure that will happen.
